I've a problem with registration adjustment of my sony 1252 QM.
When I do the adjustment procedure everythings works.
Only two keys has no effect on the patterns and only for the green tube.
The BOW and PIN keys, only during the adjustments of the green tube, has no effect on the patterns on the horizontal line (for the vertical line they work good).
So I can't (in the green hatch pattern) put parallel the top and bottom horizontal lines of the pattern (and than of the image) .
Which is the problem ?
The only passage of the adjustment procedure that I haven't followed is the one described at page 68 of the manual, where I read: ".. Here reduce the masking at the minimun (the picture is projected at the largest size), and after the registration adjustment is complete, perform the blanking adjustment to fit the screen used".
But if I do so, the patterns go out of the screen limits and I can't do right the registration adjustment procedure, becouse I don't see the edge of the pattern.
Please halp me. It isn't funny having a curved edge of the image.
Cioci
Cioci
