(3rd time trying to submit this one with a darn picture!
I am trying to check out this unit to give to a friend. I took on the lenses and cleaned them up and found the attached.
1. I know the blue is burnt pretty bad. How bad does this look to the experts on the 1-10 scale? How do i check out the red and green tubes behind those color filters? they seem to focus much better than the blue, so they may be ok.
2. I assume by looking at the S M L on the top of the tubes that this set is setup for medium mount location. Is that correct? Also, I assume in order to set to small i am going to have to buy new spacers?
3. How the H E double toothpicks do i set this machine up for floor vs. ceiling and front vs. rear projection? I am sick of reading everything backwards!
4. the little board on the back for the ir sensor is broken in half. is this something i would order from a Curt or from sony?
