Without a meter and service manual (and taking it down) you're kinda stuck. The 1270 has no internal LED to give hints as to where the problem is, and this problem can be due to ANY board in the set. The most common boards to fail are the two right under the top cover, see here:
http://www.curtpalme.com/Sony125x_Layout1.htm
you can send those boards to me for testing if you want, I have a 1270 test chassis here.
