I'm very confused. I have a 1272Q that I was running with a DVDO line doubler. I had to switch the jumpers inside the DVDO to get it to sync on green in order to get an image projected--that was all well and good for awhile. NOW, though, I have recently purchased the Rock+ video processor and brand new cables, and the 1272 cannot get a signal through the RGBHV cables! All that shows up on the screen is NO INPUT. I tried connecting my laptop to the 1272 using the VGA to RGBHV cable that came with the DVDO (to see if it is possibly a problem with the Rock+ or the new cables), and got the same NO INPUT message. Does anyone out there know what might be wrong here? I'm getting really bummed out, because it should work according to everything I've read (I spent several hours last night looking through old threads to see if anyone else has had a similar problem to no avail). I've used the menu system to change the clamp settings from AUTO to SonG to H/C to H.P and back to AUTO without any success. I guess the next step is to hook up my monitor to the Rock+ to make doubly sure that it's some kind of interface problem with the projector. In any case, any help at all would be greatly appreciated...
