What mounting bolts are needed to ceiling mount a Sony 1292 projector? I have the mount (not the PSS-1270), but no bolts.
One Installation manual (3-800-605-24(1)) calls out M8 10-25 mm metric screws and another (3-800-605-21(1)) calls out M8 38-43 mm metric screws.
M8 10mm - 25mm vs. M8 38mm-43mm ?
Neither source identifies the pitch of the thread??? And while I'm asking - why do they refer to the item as a screw? Isn't it a bolt?
What do you recommend? Do you think strength ratings of 8.8 are sufficient or should I look for 12.9 parts?
Ed
Ed
