61 - 77 of 77 Posts
UPDATE
So I phoned Costco this morning, I arranged for a replacement TV to be sent out and I have to get UPS to pick up the defective TV
The calibrator is coming to my house today. I need your opinion. What is the best set for pro1 and pro2 -> Day and night or SDR and hdr? By the way, the Dolby set where do I memorise it? On “personal”? Thank you
Sony Bravia XBR-A8H SDR Settings (@100 nits)
Picture Mode: Custom
Brightness Menu
Brightness: 26
Contrast: 90
Gamma: -2
Black Level: 50
Black ADJ: Off
Adv. Contrast Enhancer: Off
Peak Luminance: Off
Color Menu
Color: 50
Color Temp: Expert 1
Live Color: Off
Clarity Menu
Reality Creation: -
Resolution: -
Smooth Gradation: Low
Motion Menu
Motionflow: -
Smoothness: -
Clearness: -
CineMotion: Auto
ADV Color Temperature Menu
ADV Color Temperature Basic
R-Gain: max
G-Gain: Max
B-Gain: max
R-Bias: 0
G-Bias: 0
B-Bias: 0
ADV Color Temperature Multi Point (20p)
Point 1
-10
-8
-9
Point 2
-20
-17
-18
Point 3
-32
-27
-29
Point 4
-42
-35
-38
Point 5
-36
-32
-33
Point 6
-29
-26
-27
Point 7
-27
-24
-27
Point 8
-21
-28
-23
Point 9
-18
-16
-21
Point 10
-13
-12
-18
Point 11
-12
-11
-18
Point12
-10
-8
-17
Point 13
-9
-7
-18
Point 14
-8
-6
-17
Point 15
-7
-4
-16
Point 16
-6
-3
-15
Point 17
-5
-1
-13
Point 18
-4
1
-11
Point 19
-4
1
-11
Point 20
-4
0
-11
Per Color Adjustment:
Red:
Hue: 0
Saturation: 1
Lightness: 5
Magenta:
Hue: 4
Saturation: 2
Lightness: 3
Blue:
Hue: 1
Saturation: 1
Lightness: 0
Cyan:
Hue: 1
Saturation: 0
Lightness: 1
Green:
Hue: 0
Saturation: -2
Lightness: 1
Yellow:
Hue: -4
Saturation: -2
Lightness: 3
Sony Bravia XBR-A8H HDR Settings
Picture Mode: Professional 1
Brightness Menu
Brightness: Max
Contrast: 90
Gamma: 0
Black Level: 50
Black ADJ: Off
Peak Luminance: High
THE SAME SDR
THE SAME SDR
THE SAME SDR
Sony Bravia XBR-A8H Dolby Vision Settings
Picture Mode: Dolby Bright and Dark
Brightness Menu
Brightness: Max
Contrast: Max
Gamma: 0
Black Level: 50
Black ADJ: Off
Color Menu
Color: 50
Live Color: Off
Clarity Menu
Reality Creation: -
Smooth Gradation: off
Motion Menu
Motionflow: -
CineMotion: Auto
THE SAME SDR
THE SAME SDR
Red:
Hue: 0
Saturation: 0
Lightness: 0
Magenta:
Hue: 0
Saturation: 0
Lightness: 0
Blue:
Hue: 0
Saturation: 0
Lightness: 0
Cyan:
Hue: 0
Saturation: 0
Lightness: 0
Green:
Hue: 0
Saturation: 0
Lightness: 0
Yellow:
Hue: 0
Saturation: 0
Lightness: 0
Brightness Menu
Brightness: 26
Contrast: 90
Gamma: -2
Black Level: 50
Black ADJ: Off
Peak Luminance: Off
Color Menu
Color: 50
Live Color: Off
Clarity Menu
Reality Creation: -
Resolution: -
Motion Menu
Motionflow: -
Smoothness: -
Clearness: -
CineMotion: Auto
R-Gain: max
G-Gain: Max
B-Gain: max
R-Bias: 0
G-Bias: 0
B-Bias: 0
Point 1
-10
-8
-9
Point 2
-20
-17
-18
Point 3
-32
-27
-29
Point 4
-42
-35
-38
Point 5
-36
-32
-33
Point 6
-29
-26
-27
Point 7
-27
-24
-27
Point 8
-21
-28
-23
Point 9
-18
-16
-21
Point 10
-13
-12
-18
Point 11
-12
-11
-18
Point12
-10
-8
-17
Point 13
-9
-7
-18
Point 14
-8
-6
-17
Point 15
-7
-4
-16
Point 16
-6
-3
-15
Point 17
-5
-1
-13
Point 18
-4
1
-11
Point 19
-4
1
-11
Point 20
-4
0
-11
Red:
Hue: 0
Saturation: 1
Lightness: 5
Magenta:
Hue: 4
Saturation: 2
Lightness: 3
Blue:
Hue: 1
Saturation: 1
Lightness: 0
Cyan:
Hue: 1
Saturation: 0
Lightness: 1
Green:
Hue: 0
Saturation: -2
Lightness: 1
Yellow:
Hue: -4
Saturation: -2
Lightness: 3
Brightness Menu
Brightness: Max
Contrast: 90
Gamma: 0
Black Level: 50
Black ADJ: Off
THE SAME SDR
THE SAME SDR
THE SAME SDR
Brightness Menu
Brightness: Max
Contrast: Max
Gamma: 0
Black Level: 50
Black ADJ: Off
Color Menu
Color: 50
Live Color: Off
Clarity Menu
Reality Creation: -
Motion Menu
Motionflow: -
CineMotion: Auto
THE SAME SDR
THE SAME SDR
Red:
Hue: 0
Saturation: 0
Lightness: 0
Magenta:
Hue: 0
Saturation: 0
Lightness: 0
Blue:
Hue: 0
Saturation: 0
Lightness: 0
Cyan:
Hue: 0
Saturation: 0
Lightness: 0
Green:
Hue: 0
Saturation: 0
Lightness: 0
Yellow:
Hue: 0
Saturation: 0
Lightness: 0
Are these post calibration settings ? Thanks !
Discussion Starter #67
I tried to do a 20 point cal, used point 17 (80% stimulus) and the adjustments didn't move the meter at all? Is point 17 80% ?
bob
No, it should be 16.
100%=20, 95%=19, 90%=18, 85%=17....
But try setting contrast to 100 during grayscale manipulation.... if not already done. Please let me know if it helped you and your TV reacts correct on the changes.
in this post it is also mentioned:
Discussion Starter #69
Thanks, So contrast to 100 for all stimulus points? If I want to a quick WB check, should I pick 80% or 100% white? (16 or 20 point)
for a quick white point check if you want to call it like this - take the 2p controls gain on the 80% or the 100% - you will see what will be better at the curve displayed from your software e.g. calman.
don't take the 20p for this!!!!
I do it like this: I don't touch the 2p settings during my calibration session - I'll just use the 20p controls for 5%,10%,15%.... up to 100%. And for this I set contrast to 100.
Discussion Starter #71
I did, but not happy with it. I need to do again with contrast 100 to see if it really changes?
bob
Discussion Starter #72
How do I adjust CMS? I have Chromapure. My yellow hue wanted 19 clicks away from green to get in the dot. Could that be right?
Officially we recommend never using the two point. He disagrees, That being said you can use whatever you want , you just need to understand the consequences and what happens to the other picture modes that share that color temperature preset.
Tyler, can you expand on the consequences? Is it just that you will be tied to the 2pt adjustments across picture modes and color temperature presets or is there anything else to consider? I was thinking of doing 2pt gain adjustments before autocal on my next calibration (2k hours), but I would like to understand the consequences.
I'm in the same boat. Black crush is just brutal in dark scenes on the A8H. I was just test watching The Descent........black crush was all over the place. Raising my black level a point or 2 helps but I did not pay 2 grand for this problem.
Is this a problem with this model across the board, or do some of us gotta play the 'panel lottery'?
I still have a couple months return window at Costco, but what is the point of getting a replacement if all the panels suffer from noise and crushing
I have the A8H in a dark room. Thinking of upgrading to the A90J as the A8H seems a little too dark. I would like the darker items (near black) to open up. Netflix has some pretty bad black crush in dark scenes, e.g. Jessica Jones. Might be Netflix?
But even Robert Zohn from Value Electronics says the A90J might be too bright for a dark room. Opinions please?
Don't get carried away by PR related numbers .. A8H is perfectly fine. Do you wanna wear sunglasses at explosions etc. Do you wanna replace a Tv not even a year old and pay big box for some incremental difference you probably won't even see .. then after a week when you have gotten used to that picture something new arrives and circle continues. Take it easy my man and buy something else nice for yourself.
Has anyone any DETAIL information on what all the DEVELOPER OPTIONS do, PROs and CONs.??
Is there possibly an instruction manual for all the Developer Options posabilitys/capabilitys?? I was not able to locate an instruction/explanation manual for the DEVELOPER OPTIONS capability of this TV.
61 - 77 of 77 Posts
