I just did the next best thing...copy & paste!! Optimized Picture Settings
PICTURE SETTINGS
Picture Mode: Custom
Aspect ratio: Full (Display Area: Full Pixel)
Contrast: 90
Black Level: 51
Gamma: Min
Color: 55
Hue: R6
Sharpness: 35
Color Temperature: Expert1
Brightness: 27
CineMotion: Auto
HDR Mode: Auto
HDMI Video Range: Auto
Color Space: Auto.
All other settings should be set to "off" or zero "0." Any individual R,G, or B color subcontrols, if present, should remain at their default settings.
TV FIRMWARE: All models are evaluated using the latest firmware version available at the time of testing. The firmware version of the Sony XBR-75X800H was: PKG6.4770.0615NAA.
HOW TO ADJUST YOUR TV SETTINGS: Our expert TV testers recommend the above settings for the Sony XBR-75X800H to get your image looking like the rated picture quality we saw in our lab. The settings shown are available when your playback device (i.e. cable box) is connected to the TV’s HDMI input. Some settings may not be adjustable when streaming videos directly on the TV. To access the picture controls find the Menu, Home, Settings, or "Gear" icon on your remote or on-screen display, and navigate to the picture settings menu where you’ll see most of the controls. To find some other controls you may additionally have to enter the "advanced settings" or the "picture options" sub-menus (name may vary depending on model). Don’t worry about making any "mistakes." You can always reset the picture settings to factory default if necessary. Consult your user manual for additional guidance.
ABOUT CR’s OPTIMIZED PICTURE SETTINGS: Our fine-tuned picture adjustments are made with the support of special test patterns and reference videos to yield the best image fidelity. A professionally calibrated reference display is used for comparison. Whether you are watching movies on Blu-ray or sports from your cable box, these settings will ensure you are seeing the programs in the best quality that the model can offer, short of a professional calibration. When we optimize the image, we typically turn off special features (or turn down their settings) that can degrade performance, including; power saving modes (which often dim the image), sharpness, noise reduction (also known as DNR, a feature that can degrade image detail), and "motion smoothing," if present (an effect that can give movies a soap-opera video-like appearance). Optimal settings for your TV may vary a bit from ours due to slight variations between similar samples, or due to a newer version of the TV’s firmware.
ABOUT CR’s TV VIEWING CONDITIONS: Our picture settings are optimized for a darker viewing environment. If you are viewing primarily in a brightly-lit room, we suggest raising the Backlight control (not the Contrast) to brighten the image to a level that looks suitable. Additionally, you may want to lower the Gamma setting (if available) by one or two increments to better reveal darker shadow detail. If the settings we recommend don’t suit your taste or your viewing environment, use the picture controls to achieve an image you consider "just right."
