Status
Not open for further replies.
1 - 2 of 2 Posts
Discussion Starter #1
I just have a couple of simple questions on Sonys 24 inch oval dish with dual LNBs. I've heard that it includes a 4 way multiswitch. Is this correct? And is this multiswitch meant to be mounted outside on the dish or nearby, or does it need to be mounted inside? I only have 2 receivers now and I have 2 lines already run to the house. If the switch can be mounted outside, I can use my additional wiring without having to run 2 more lines, correct?
All of the oval dishes that I'm aware of come with a 4-way multiswitch. Typically, the dish has mounting holes on the back of it to allow the multiswitch to be mounted directly to the dish. The switches are designed for outdoor installation, but like any other elecronic device, they might be better off out of the weather.
Yes, you can mount your switch on the dish and use your existing cables.
1 - 2 of 2 Posts
Status
