Status
Not open for further replies.
1 - 4 of 4 Posts
I'm trying to help a friend out with an interesting request.
He owns a Sony VAIO PC and the Sony 32HS510, both have a "Memory Stick" slot.
He purchased a Memory Stick with the hope to display scanned family photos on the display. However, the only pictures that will display are those that were taken with a Sony Digital Camera.
What can we do to the scanned photos to allow them to be "read" and displayed on the TV ??
Thanks much,
Todd.
I believe the tv will only see a certain "File Type". He will probably need to change the scanned photos to the proper file type which the Sony Camera makes natively (thus no conflict).
Not sure what the file format is off the top of my head but it is worth a check.
Joel
Discussion Starter · #4 ·
You both are correct.
I've discovered the file format is a 'special' JPG type. Using "Picture Gear" I've successfully saved the scans to the Memory Stick format.
Thanks !
1 - 4 of 4 Posts
Status
