So far as I am aware, the anti-glare on all of these CRTs is a film, not a "coating," that would have been sprayed on. Steel wool is exactly what people have used to remove it safely even in instances like this, maybe getting it started with an xacto knife. If you want to try pulling it off instead I recommend you try to source the service manual and inspect its diagrams carefully for the slots, tabs, bolts and other attachments that go to the front bezel. It isn't rocket science and several people have even done it without manuals or personal walkthroughs. Just look carefully as you go and you should be able to manage it without damaging anything. From your pictures I would expect that the bolts you pictured need to be removed, but also be on the lookout for tabs and slots to pry up, down, left or right.
That's what I think too with all of the accounts on here from other 960 owners saying they had a film. I just don't want to scratch the glass or black bezel with the steel wool. I also want to get rid of the entire film around the glass. Not just what shows up on the screen.
The green arrows here show the approximate locations of all the golden screws around the perimeter of the casing. I removed all of the golden screws where the green arrows are, but still couldn't get the front off. There are two tabs on the left and right side of the TV which you can push. When I pushed them both, the black bezel looked like it was slightly coming off, but no farther than that. The red crosses I did not remove yet. I'm not sure those gold screws with the washers behind them affect the black bezel removal, so I left them. I think they hold that weird thing that shows in front of the picture up.
The red cross here is what I've heard you're NOT supposed to remove. There are 4 of those large silver screws around each edge of the TV that hold it with the cabinet. Also, I don't think removing those would help in removing the black bezel. Its impossible to turn them anyway with a Phillips Screwdriver. They won't budge, and probably for good reason.
I'm not sure if removing all 4 of the orange ? screws would help in removing the black bezel in any way.
The green "cabinet screw" just shows one of the screw holes that connects the back casing of the TV onto the backside of the TV. That's step one, which was easy and had absolutely no trouble with. Step two is removing all of the gold screws around the perimeter of the TV inside, which I did. But I still couldn't get the black bezel off. I felt like I would break the plastic if I pulled too hard.
Any help here?
