I'm trying to determine what would be a good replacement for my 400Q. When I look at some of the candidates, I get concerned about screen door. I believe that the Sony is about 1,000 x 480 pixels with the delta pattern. I must admit that I like the way that the Sony looks up close pixel-wise. If I go to a 1024x768 projector at 16x9, I don't gain a lot of pixels and I loose the delta pattern. Does this realy matter?
If you have owned a 400 in the past, what did you upgrade to, and how does it compare to the Sony, especially in the screen door area?
If you currently own the 400Q, what size screen are you using and what material? I do want to upgrade my screen, no matter what, from 87" wide to 120" wide. My viewing distance is 14 feet and I like the "immerse" feeling of large screens.
Chuck Davis
Chuck Davis
