Status
Not open for further replies.
1 - 4 of 4 Posts
Hi All.
I picked up a Sony 4es yesterday and found the remote to be very wife unfriendly. I picked up a kameleon today, but there is no code for the 4es. Anyone else have this combo? Any work-a-rounds? I really like the remote other than that problem.
As always any info is appreciated,
Zaxdad
Premium Member
All new sony receivers are using a new code set, that is the factory default, you need to change the code your receiver responds to, by changing it to the old code set, AV1. On the ES series receivers I believe you need to enter the menu to change modes, you also need to change oem remote. Check the manual. Once you switch from AV2 to AV1, the codes in the kameleon will work.
1 - 4 of 4 Posts
Status
