SONY 55X900F+Audio vs 65X750F+Audio vs 65Z9F
278 Views 4 Replies 2 Participants Last post by  KING DRANZER
I am unable to decide between two options. SONY 55X900F and 65X750F. Which will give me better visual experience. I can get both of them for similar price and in addition can get Audio system. I do have a third option which is bit crazy as I will have to import it to my place, but I can get 65Z9F without the addition of Audio system. Is Z9F worth the pain of importing and skipping on audio system over previous two options.
1 - 5 of 5 Posts
Go with the Z9F and get audio system later. It is the best one out of listed choices.
If I go for Z9F I won't be getting Audio system at all. At-least not for Years. Bit hard to decide. But if Z9F is really worth the visual experience then will definitely get that. How many watts speakers does Z9F comes packed with.
If I choose not to go with the Z9F then what is next best option out of the two
If Z9F becomes unattainable. Which second option be better 65X750F or 55X900F
1 - 5 of 5 Posts
