I recently "upgraded" from a Sony 655 5 disc dvd to the 685 because of the SACD function. This week the picture started to jitter and shift at the top of the screen. It happens intermittantly, with different discs, only in progressive mode. If I switch to interlaced, the problem goes away. Other than the player, my system hasn't changed and my old 655 worked fine in the system.
Given the fact that my 655 appears to work ok and the 685 only acts up in progressive scan mode, the player must be bad, right? I double checked all connections and I'm using decent component cables. I am running the DVD output through the component inputs on a Sony DA5ES receiver and then to the component inputs on a Sony 57" WV700 tv.
Any thoughts out there?
