Well, that would be a no go as far as I am concerned. The release notes do not say anything about internal apps only. Unless Sony decides to put in writing their plans I may be looking at returning my 65" and wait it out. Too much $ to spend on a manufacturer that half delivers a promise. Seen it before and not willing to gamble on a potential unfulfilled promise. It's Jan 2018 for gosh sakes.This is from the ATV4K thread:
"I did reach out to John Archer from Forbes and he's looking into it. He wonders if they limited support via HDMI until that DV fix could be released. He said he'd reply if/when he hears anything."
Could be they released SW for the internal apps, but are waiting on HDMI sources until DV lets the black level update loose.
Someone in the 940E thread cannot get DV to trigger from an Oppo 203, using two different discs.Well, that would be a no go as far as I am concerned. The release notes do not say anything about internal apps only. Unless Sony decides to put in writing their plans I may be looking at returning my 65" and wait it out. Too much $ to spend on a manufacturer that half delivers a promise. Seen it before and not willing to gamble on a potential unfulfilled promise. It's Jan 2018 for gosh sakes.
Does this mean the update support DV Apps only and not DV over HDMI?Someone in the 940E thread cannot get DV to trigger from an Oppo 203, using two different discs.
That appears to be what everyone that has tried is seeing.Does this mean the update support DV Apps only and not DV over HDMI?
- Rich
Right. Which means the question has been answered with a "yes".I thought someone said DV is working now on the netflix internal app.
Not sure which apps now have DV support.
Does amazon?
Does USB file playback?
I will have to check when I get home and can install the update.
Bosch Season 2 is in Dv that’s what I used didn’t have to update the app.Which amazon movie/tv show did you see it on, want to check on my end. Do I need to update the amazon app first?
From Sebring5: http://www.avsforum.com/forum/40-ol...ly-thread-no-price-talk-105.html#post55508342cool, thanks, will check tonight after I update tv. How can I tell that DV is displaying correctly. Does DV banner pop-up automatically or do I need to go to a setting somewhere to see it.
does this same notification occur when HDR is being displayed?From Sebring5: http://www.avsforum.com/forum/40-ol...ly-thread-no-price-talk-105.html#post55508342
"There is a setting called notification in picture & display that has to be turned on to notify when a Dolby Vision signal is detected."
