1 - 5 of 5 Posts
I've had a Sony KDS-50A2000 for around 3 months, and this weekend I tried to turn the TV on but got no picture. The power LED flashed green for a while, then started flashing red. The bulb doesn't turn on, but you can hear the fans and power come on. The TV does this whenever I try to turn it on.
Has anyone seen this issue before and know what's up?
I had this happen on mine. If you look in the manual it tells you how to do a full reset. You hold down a button on the remote while pressing one on the tv. It worked for mine and have not had an issue since.
Discussion Starter · #4 ·
I gave that a shot but it didn't seem to do anything.
Originally Posted by mjg100 /forum/post/0
You need to count the number of times that the light flashes. The number of flashes repeats every few seconds. The sequence is anywhere from 2 flashes to 9 flashes.
It flashes 5 times.
According to the service manual, 5 blinks of the power indicator means its a problem with the lamp driver being faulty, in which the case the lamp is turned off.
You need to make the call to get your warranty provider to service your TV.
1 - 5 of 5 Posts
