I'm considering the persuit of warranty service on my Sony 55A2000 due to it's Green Haze problem that makes fleshtones look green, but wanted to get advice from others on the forum that have gone this route. Here are some questions that I have...
1. Has anyone had permanent correction with this problem after repair (short of a full TV replacement)? If so, what worked....optical block replacement, etc?
2. What is the best way to demonstrate this problem to the repair technician to avoid denial and finger pointing? (I also have the Green Donut with Purple Ring I can point out).
3. Does Sony allow you to pick from a list of auth service companies in your area? If so, can someone recommend one in the Pasadena/San Gabriel Valley, CA area?
4. If this ends up escalating to the level of Sony offering a replacement, would I be foolish to accept a newer unit of the exact same model? There really is no other Sony that I would want to upgrade to, mainly due to cabinet size constraints (Dumbo Ear models will NOT work for me).
5. Is it a bad idea to even go down the repair road period? Should I just adjust my color settings as much as possible to reduce the effect, live with it and just avoid sony products in the future? I'd hate to get it worked on and end up with a problem worse than what I have now (I've read horror stories about loss of detail and motion blur issues after repair work on this set).
M
M
