1 - 4 of 4 Posts
Hi All,
I'm having trouble syncing my remote to my PS3. I tried everything said on these forums, and yes I tried new batteries
. I have upgraded my HD about a year ago, not sure if this has anything to do with the problems. I can sync a controller & BT headset without any problems. I also bought a new remote and that also didn't work. Any help would be much appreciated.
rwings
Did you go into Accessories > Register BD Remote > set the PS3 to search and then press and hold the ENTER and START buttons on the BD REMOTE?
Discussion Starter · #3 ·
Hi KS,
Yes I did. I finally got it to work
, I unplugged the PS3 for about an hour(went out), did a factory reset and BD remote synched.
rwings
Cool. Glad it finally worked for ya!
1 - 4 of 4 Posts
