Sony BDP-S1: Uncompressed Multi Channel Linear PCM Output
1320 Views 4 Replies 3 Participants Last post by  JOHNnDENVER
Hello,
What is the HT processor requirement to be use the Uncompressed Multi Channel Linear PCM Output format?
Will a standard DD DTS processor such as the Theta Casanova be able to to use this imrpoved sound format?
thank you
1 - 5 of 5 Posts
Also
Dolby® Digital Plus (Dolby® Digital audio stream only), Dolby® TrueHD (Dolby® Digital audio stream only) dts®-HD --- (dts audio stream only) Digital Out and decoding capability
Can anyone talk about those formats? Do you need something else in the processor on top of standard DD and DTS capabilities to run those?
Originally Posted by goatwuss /forum/post/0
Hello,
No.
Also
Yes.
The player has to decode them and either send it via HDMI or 5.1/7.1 analog multi-channel.
1 - 5 of 5 Posts
