1 - 1 of 1 Posts
Hi, recently acquired Sony Bravia KDF 50E 2010 from a family member, have been told that set did work previously without problems. However seems that the lamp refuses to stay on and get solid red lamp light and blinking standby after failed start. Set has recently had new lamp, seems fine as does come on briefly nice and bright,
Ok bad bits!.... The settings for lamp init have possibly been changed as previous owner messed with service menu trying to reset lamp timer, problems seemed to start after set was turned back on. Prior to this all was apparently well. Seemed to good a tv to toss away, unfortunately have exhausted all avenues!!:mad any help would be much appreciated. Andy.
1 - 1 of 1 Posts
