1 - 9 of 9 Posts
· Registered
Discussion Starter · #2 ·
Key Features
-16:9 Full HD 1080p Resolution Panel (1920 x 1080)
-Motionflow 60Hz technology
-24p True Cinema 1
-BRAVIA® Engine 2 fully digital video processor
-DMe capable x 2
-Favorites function w/rich graphics
-Xross Media Bar (XMB ) user interface
-TV Guide Interactive Program Guide ®
-Optimized Theater Mode
-S-Force Front Surround ®
-BRAVIA Sync capable ® 3
-Up to 1080/24p input capable via HDMI interface x4
-HD Component YPbPr x2 (1080/60p capable)
-PC Input x1
-USB Input x1
-S-Video Input x1
Key Technologies
16:9 Full HD 1080p resolution 16:9 Full HD 1080p resolution panel (1920 x 1080) accepts any HDTV signal and renders it with 1080p resolution.
Motionflow 60Hz technology Motionflow 60Hz technology allows you to enjoy movies and primetime TV (film-based content) with a clarity and resolution in motion that will spoil you. Sony's motioncompensation algorithm, which we call Motionflow, identifies film content and removes judder.
That means you'll get a clearer picture during sweeping pans with reduced visible jerking or stuttering.
24p True Cinema 24p True Cinema lets you enjoy films at their intended 24 fps (frames per second) when viewed using a 24p capable output device, such as a Blu-ray Disc player.
BRAVIA® Engine 2 BRAVIA Engine 2 fully digital video processor significantly reduces noise, enhances overall image detail, and optimizes contrast.
Expandability DMe functionality2 allows you to expand your HDTV's capabilities by connecting optional BRAVIA® Link Modules, such as the DMX-NV1 BRAVIA Internet Video Link module (sold separately).
Favorites function The Favorites function feature rich graphics capability that makes it easy and fun to quickly access video content and digital photos to share with family and friends.
Xross Media Bar Xross Media Bar (XMB ) graphical user interface makes it simple and intuitive to navigate the television's menus, controls, and user settings.
TV Guide® TV Guide® Interactive Program Guide is integrated into Sony's exclusive xross media bar user interface to deliver continually updated program.
Optimized Theater Mode Optimized Theater Mode enhances film nuances to give you a nearly theatrical viewing experience.
S-Force® Front Surround S-Force® Front Surround generates realistic virtual surround sound from the two speakers in the TV.
· Registered
Discussion Starter · #3 ·
Specifications
General
Television Type: Flat Panel LCD HDTV
Display
Viewing Angle (Right/Left): 178°
Viewing Angle (Up/Down): 178°
On-screen Contrast Ratio: 2,500:1
Dynamic Contrast Ratio: 25,000:1
Screen Size (measured diagonally): 32" Class (31.5")
Native Resolution: 1920 x 1080
Display Resolution: 1920 x 1080p (Full HD)
TV System
Tuner (Cable): QAM Tuner
Tuner (Terrestrial): ATSC / NTSC
TV System (Analog): NTSC
Number of Tuners (Analog): 1
Number of Tuners (Digital): 1
TV System (Digital): ATSC
Video
Video Signal: 480/60i, 480/60p, 720p, 1080/60i, 1080/24p
(HDMI only), 1080/60p (HDMI / Component)
Video Processing: Bravia Engine Technology
CineMotion® Reverse 3:2 Pulldown Technology: Yes
Game Mode: Yes
Wide Mode: Wide Zoom, Normal, Full, H Stretch, Zoom
3D Comb Filter: Yes
MPEG Noise Reduction: Yes
Auto Wide: Yes
4:3 Default: Yes
24p True Cinema Technology: Yes
Picture Mode: Vivid, Standard, Cinema, Custom; Photo-
Vivid, Photo-Standard, Photo-Original, Photo-Custom
Advanced Contrast Enhancer (ACE): Yes
Audio
Audio Power Output: 20W (10W x2)
Inputs and Outputs
Component Video (Y/Pb/Pr ) Input(s): 2 (Rear)
Composite Video Input(s): 3 (1 Side/2 Rear)
Digital Audio Output(s): Optical Digital Output - 1 (Rear)
RF Connection Input(s): 1 (Rear)
S-Video Input(s): 1 (Rear)
Analog Audio Input(s) (Total): 6 (1 Side/5 Rear)
HDMI Connection(s) (Total): 4 (1 Side/3 Rear)
PC In (D-Sub) + Audio In (Stereo Mini): 1 (Rear)
HDMI PC Input Format Support: Yes
HDMI PC Input: Yes
S-Video Detection: Yes
PC Input Format Support: Yes (see manual for exactformats)
Power
Power Consumption (in Operation): 160W
Power Consumption (in Standby): 0.1W
Power Requirements: AC 120V
Regulation and Standard Compliance
Energy Star® Compliant: Yes
VESA® Hole Spacing Compatible: Yes
VESA® Hole Pitch: 200 x 200 mm, M6 Screw Type, 16mm
· Registered
Heticor,
Be pleased that you purchased a re-badged 32" XBR6 (or a 32" V4100)
Your TV is cheaper and has an "M" series Sony bezel. I've posted a thread here:
avsforum.com/avs-vb/showthread.php?t=1102053
and asked about any differences to which I haven't yet had a reply. Methinks all the 32" XBR6 owners just found out they could have had virtually the same set but at a cheaper price... (I got my VL140 for $699 CDN).
The 32VL140 also has the Live Color Creation feature as well.
· Registered
Discussion Starter · #5 ·
thanks for your answer.
I am very please with this tv, I did the software update I dont know if that was a good desicion , however i do not notice any difference with the previos version.
· Registered
Discussion Starter · #9 ·
I was watching Walle, trought the component 1 input , each time that Evas blue eyes where in fist plane a horizontal a red line at the same high of the Evas eyes appear across the whole screen. it was not a solid line , it was clear.
same thing happen with some yellow robot a clear blue line shows up.
I wonder if this problem came from the component input or something related with the tv itselft.
any ideas.
Up date: the signal is feed from satellite receiver throught component, I switch cables and did not change. I replace the component by composity and the lines disapear. I read in other threads similar problems with satellite and component.
1 - 9 of 9 Posts
