Status
Not open for further replies.
1 - 2 of 2 Posts
Hi all,
finally i solved the "pj-multi" problem and i want to share the solution with the
community.
Mainly because of the Sony policy that sells an awful cable, limited in lenght (max.5mt) at a terrible price: all that thanks to the pj-multi proprietary connector.
Following the pinouts:
1 nc
2 nc
3 nc
4 Audio - R
5 Blue (B-Y)
6 GND
7 GND
8 Audio - L
9 Green (G-Y)
10 GND
11 GND
12 H
13 Red (R-Y)
14 nc
15 GND
16 V
17 nc
18 nc
19 Y
20 DDC SCL
21 GND
22 nc
23 C
24 DDC return
25 GND
26 nc
27 C-video
28 DDC SDA
29 GND
30 nc
31 nc
32 nc
and the order of pins , watching the connector from the wire
clipping side (the side where you put in the wires on the connector) is:
31-29-27 ...............5-3-1
32-30-28 ...............6-4-2
If you want to build an adapter with the connector that is on the cable that comes with the cineza you can, but pay attention because you need a lot of patience due to the extreme thickness of the wires that are compatible with the pj-multi: my advice is to mantain the adapter as shorter as you can and use a "wire-wrap" cables.
If you want to send to cineza an 15k RGB signal don't forget that you must connect the syncro signal of your source(that usually is on the Composite-Video) on the pin 12 (H sync) of the pj-multi. Obviously other connections are between R, G and B pins.
Is not recommended to use for GND the pin 29 because it has a resistor on the cineza internal , while all other GND are connected each other on the cineza side.
I've succesfully built, after a lot of unsuccessfully trials, a SCART-PJMULTI and a VGA-PJMULTI connector.
The cable that Sony use for their optional (and exceptionally priced) cables is the LTK cable that you can find here: http://www.ltkcable.com/LTK_p_20379.htm
Hope all that helps people to have a better connection at a reasonable price.
bye
elche99
hey not sure if you are still watching this post but i was wondering which pins i would be using to connect a hd15 connector so i can hook my laptop to the projector. thanks in advance jeff
1 - 2 of 2 Posts
Status
