Can the Sony HT-CT 150 work with a Power Toggle Setting?
I'm trying to set up my Harmony 700 remote with the 150, and the CT won't turn OFF with the default settings on the Harmony, when you switch to an Activity that *doesn't* require it. I need to know if Power Toggle will work, or if I will have to do the "learn" remote process?
I haven't had much luck with Harmony's "learn" feature in the past, and I'm hoping I can get around it. TIA for any advice.
