Hi,
I've had my D50Q for almost two years now and have had zero problems. Lately, I've started to notice that during black or very dark scenes, there is a sort of "horizonal flashing" apparent on the screen which was never there. I can only describe it as streaks of lighter areas flashing on the screen - sort of like horizontal lightning in a way.
Looking directly into the CRTs, I can see a lot of horizonal "noise" in the green and red guns (especially in the green) and none in the blue.
I never checked before, because it was never a problem on the screen, but I would assume looking into the tubes directly should not yield this messy result.
I should note that during normal viewing (i.e not dark scenes) this is not even noticeable. So how is it related to dark scenes? I'm baffled. What is the relation??
I've ruled out cabling, DVD players, and processors, as I've plugged in different combos, some players even directly into the S Video input on the projector (i.e. no doubling even). So I'm thinking it must be either the tubes (but can they all be bad??) or a power supply issue, or some other electronic/input issue.
Has anyone seen this on this, or on any other projector? Before I call Sony and dish out labor money I would like to understand it better.
BTW, I found this thread from back in February. It may or may not have been the same issue - I don't know.
Bogdan
Fellow D50Q owners,
I have had my unit for about a year and now I am running an Elite DV37 progrssive DVD player component wire into the RGBHV inputs. I just started to notice that on dark scenes black areas gradually shift lighter and back to dark again. This whole cycle happens within about 10 seconds.
It's hard to notice except on specific scenes. I have hooked the DVD player directly to the back of the D50 to make sure it's not a wiring problem and I even tried one of the Richard Gray power conditioners thinking it might be the power in my house.
Any suggestions? What does a bad power supply do?
thanks, joe
Bogdan
Fellow D50Q owners,
thanks, joe
