I just bought a Sony DVD recorder model RDR-GX355 and it does not have a remote. Before I take it back, is it possible to make my Comcast remote do all the functionality that I will need?
My Comcast remote has the grey OK/Select button in the center. I have programmed it with a couple of 4-digit codes that have not worked, including 1759. On a couple of codes, I can see that the remote has communicated with the device since the readout on the device changes to "DVD 3" with some of the codes, but none perfectly. In one case, I tried the 994 command with it thinking that I could use the codes here:
hifi-remote cot com/sony/Sony_dvd
but it didn't work. I have not reset it since then (I don't know if this matters).
Any help would be appreciated. Thanks in advance!
