Status
Not open for further replies.
1 - 6 of 6 Posts
I had a n00b question about hooking my WeGa Trinitron TV to my computer and be able to use it as a second monitor, so my buddys could watch me play Counter-Strike and not have to hang over my shoulder. I have a bunch of AV hook ups along with a S-Video. I was wondering if it was possible to hook up my computer up to it and if I needed any special cables if it was? Thanks and I hope it isn't took much of a dumb question.:confused:
Does your video card have S-video out? If so, that would be the simplest, although the quality may not be that great.
Discussion Starter · #3 ·
Yes my TV has S-video out....so what would I need to connect my Graphics card to my TV it only has a spot for a VGA cable?
Actually, I was asking if your video card (computer) has an S-video output, not the TV. It sounds as though the video card only has a VGA port though.
If you take a look at the Computer Input link in my signature, you'll see some of the higher-end options for connecting a computer to a TV. There are some other more affordable, but not as high quality options as well, like a VGA -> S-video transcoder.
What type of inputs does the TV have? And would you consider replacing your current video card with one that more directly supports either S-video or component output?
Discussion Starter · #5 ·
My TV has YPrPb and S video connection spots and my graphics card does only have a spot for a VGA hook up. I would be willing to buy a new ATI card with the support for S-Video but would this be good quality or am I better off doing something else.
You have to get an ATI that supports clone mode, or any GeForce MX or FX will work too. The video card has to have VGA and S-Video out. It will be good quality on the tv.
You could also get a converter box that will take VGA in and output VGA pass-through and S-video. This may or may not be more expensive.
1 - 6 of 6 Posts
Status
