I'm concerned that you report the image looks "too dark with gamma set on or off".
My experience in comparing the Moome HDMI IFB card with the gamma adjustment to the DVI IFB card from JohnHWMan is that I perceive no difference in brightness or contrast on most scenes - but in very dark scenes (or low IRE test patterns) the gamma adjustment on the moome card lets me run with a lower brightness setting on my projector but still see the low IRE steps. With John's card I have to raise the brightness on the projector to see the low IRE steps and sacrifice absolute fade to black.
Instructions for setting the gamma are available here:
http://www.curtpalme.com/forum/download.php?id=3086
There is also a faq on Curt's site here:
http://www.curtpalme.com/forum/viewtopic.php?t=5516
If you observe that the image is darker with the HDMI/Gamma card than it was with the DVI card then something does seem wrong.
The approach I took in adjusting the gamma on mine generally went like this:
- Insert and connect the hdmi ifb card.
- Power on the projector and pull up the Avia brightness adjustment test pattern.
- Use a small screwdriver to turn the gamma adjustment screw on the back of the moome card clockwise many turns. This effectively disables the gamma adjustment.
- Adjust the projector brightness so that I was happy with the level of background brightness. And accept that I could no longer see the moving black bars.
- Use the screwdriver to turn the adjustment screw counter clockwise to the point where I saw the moving black bars rise out of the darkness. The point at which the adjusment makes a dfference is pretty short but it was obvious when it kicked in. I set it with the screw so that I could see both bars just barely.
- Then I used the remote to pull down the gamma slightly so I only saw the one moving bar.
I also checked the same general procedure with the THX Optimizer brightness adjustment test pattern and verified that I was able to see the fifth dark grey box in their steps with the HDMI/Gamma moome card, but was not with the DVI card.
When I did my color setup with HCFR and the Spyder2 meter it was with the DVI card directly from my PC. After setting up the moome card, I connected it to my PC and checked the values and confirmed that in the higher IRE there was no real difference between the values I got with the DVI card. But the light meters I have are not very good for the low IRE readings so I was not able to get any good comparison at the low end. But looking at the low ire test patterns the difference was obvious to me.
