Folks,
This G70 is not responding to IR signals.
I have already checked that
1. Both the front and the rear IR sensors are enabled in the menu.
2. The dials are the rear are set to 0, 1 (have tried other settings too)
Is the PJ supposed to give any indication that it has received an IR signal? Like a blink of a LED somewhere?
I really don't have the actual Sony remote. I am using a Pronto CCF file on an iPaq 3955. The CCF file is for the G70. I downloaded it off remotecentral.
All other CCF files I have downloaded from there work fine. The one for my Sony 1270 also works fine on that 1270.
Just this one for the G70 does not make the G70 do anything. Hence I suspect there is something wrong on the G70.
Any Tips?
Any Tips?
