I am having a strange problem with input B on my new G70 that I bought last week. I have an IFB-11 RGB card on input B. When feeding a signal from my HTPC, the picture has a red tint that changes in intensity depending on what's showing on the screen. It is more intense when showing dark backgrounds:
http://members.aol.com/vruiz63/picture1.jpeg
When the background gets brighter it then takes a green-red tint:
http://members.aol.com/vruiz63/picture2.jpeg
Needless to say, the picture leaves a lot to be desired:
http://members.aol.com/vruiz63/picture3.jpeg
http://members.aol.com/vruiz63/picture4.jpeg
http://members.aol.com/vruiz63/picture5.jpeg
My previous projector was a Marquee 8000 which did not exhibit any of these problems when fed the same signal from the same HTPC. Also, this only happens on input B of the G70. When I connect the HTPC to input A the picture is fine. I have tried two different IFB-11 cards and the problem remains.
A couple of people have said it could be the color balance or gain/bias but if it was that why would the tint change depending on what's showing? Wouldn't it be the same regardless of the image on the screen? Also, wouldn't that show on input A as well? The fact that it only shows on input B and it's happened with two different cards leads me to believe it may be something with the input itself in the projector.
Anyone has any idea what this could be?
