Status
Not open for further replies.
1 - 2 of 2 Posts
after other peoples perspective on there type of ceiling mount, screen size and there crt distance to screen do you reduce the distance by say 6% to the screen are You using the full raster.
How low from the ceiling is your screen.
do you setup using Pjcalc or move the Pj back untill the green tube face fills your image from your primary source :D
what screen ratio do you setup on!
I am using the full raster. The H width coarse is maxed out, the H width fine is at about 120 out of 256.
With a 92" wide screen, I'm about 116" from the green lens ring to the screen surface. Don't recall how much shorter this is than the PJ Calc recommendation, but it is significant.
I use a home made Unistrut mount that allows me to set the raster size to max and move the PJ back so the image just fills the screen.
52" by 92" 16:9 screen. Wouldn't want to go much bigger. Could be smaller with no trouble. I'm getting 15 ft-lamberts at 100 IRE off of a 1.3 gain screen.
I use an HTPC and the desktop is set to the 16:9 screen ratio, which is what I set up on.
1 - 2 of 2 Posts
Status
