Does the Sony FW900 have the ability to correct the aspect ratio of 4:3 source material? Can it zoom a 4:3 letterbox source image to full screen?
If so, is it convenient to switch between stored modes & settings?
If you're using this monitor as your home theater display, do you like it?
-Bryce
http://www.ita.sel.sony.com/products.../gdmfw900.html
(Also known as the Sony GDM-FW900. Available from Dell for about $1700.00)
http://www.siimage.com/dvdo/iscanpro.asp
(iScan DVDO, a matching scan converter. I am aware that the new versions can perform the aspect ratio conversion themselves).
http://www.pioneerelectronics.com/Pi...2,2390,00.html
(Pioneer DV-440, a matching DVD player. Hopefully good
-Bryce
