HELP!!
I have a Sony HD-100 receiver and I am having problems with OTA on my unit. I had a custom antenna built to receive all the OTA channels here in the Indianapolis area. The antenna person used a spectrum analyzer to detect and test each channel so I should be okay from this standpoint.
Within my receiver's menu, SYSTEM/ANTENNA, I can test each OTA channel signal strength, resulting in 100% and locked status. Within my reciever's menu, SYSTEM/NON-SATELITE, I go through the process of auto detecting the digital TV channels. The status bar progresses and pauses indicating it has detected the channels but at the end of the process no channels are listed.
My question is do you think there is a problem with my receiver? Is there a manual way I can add these OTA channels to the receiver?
I talked to Sony on the phone and they have sent the question to their engineering department but I thought I would post this info here for feedback.
If any of you who use the HD-100 receiver could review what you did to get your OTA working, I would appreciate step-by-step feedback on how / what you did during the initial install / setup.
Geoff
Geoff
