Status
Not open for further replies.
1 - 10 of 10 Posts
Have a problem with the DD5.1. I have the optical cable plugged in but only get sound out of the front 2 speakers in the DD5.1 mode. I had the same set up with my Hughes reciever and it worked fine so the problem has to be with the HD100. It appears I have all the settings right. Has anyone seen this problem or have any suggestions. Thanks.
If you're using the Toslink (optical) cable as your audio interconnect, then the problem lies in one of two places:
1) Check the "audio" menu on your HD-100 and make sure you've selected DD and *not* PCM
2) Make sure your receiver/amp/decoder is not set on some "down-convert" mode or the DSP mode is completely off. For example, I don't engage the DSP mode on my amp, then it defaults to a down-convert/2-channel mode.
I have the same problem with my setup.
I checked the audio menu of the HD-100 and I can have DD on auto or off. It is set to auto... What is PCM?
Also, I have a Pioneer Elite 36 VSX 36TX. I have everything set to either standard or auto... Is there anything else that I need to do?
I have not seen this problem with my HD-100/Tag AV32R setup. Are you sure you are not watching a DD2.1 source?
I just upgraded by AV32R firmware since it suffered from a problem where switching between Analog and DD-based channels confused the processor and put it into Direct mode. Maybe your processor is suffering from a similar problem.
mikep
I had assumed that since he mentioned DD5.1, that he was not getting a DD2.0 signal. However, if his processor doesn't specifically tell him that (like my Yamaha does), then everything said here can be ignored.
My receiver lights up as getting a digital source, dolby digital lights up, and all 5 speaker indicator lights come on. This was on the HBO channel. On another channel that isnt a 5.1 source, digital source, with dolby digital, with only the front 2 speaker indicator lights on. So I assume that my receiver is handling everything correctly. Only problem is, that the front 2 speakers are the only ones with audio...
Discussion Starter · #8 ·
Thanks to some hints from Stanton it appears that I solved the problem. I did not have a video-in (RCA) cable connected from the TV to the Amp, since I have component video from the HD100 to the TV and optical audio from from the HD100 to the amp, I figured it wasn't necessary. But apparently the amp. uses the video input signal as an indication to switch to DD5.1. Doesn't sound very intuitive but I guess thats how it works. Thanks for the help.
Ok, I'm not sure what to do for my setup. I dont use an amp.
Do I need to have a connection going out of the tv into the receiver? And is this going to be a video or audio connection? Where would it go on the receiver?
Discussion Starter · #10 ·
Konn22 - My "amp" is actually an A/V receiver. From the TV I now have both the audio and video out plugged into the receiver on the TV in jacks. Of course I still have the optical audio directly from the HD 100 to the receiver and the component video from the HD100 to the TV. In addition the RCA audio/video is plugged in from the HD 100 to the TV. You should be able to go directly from the HD100 to your receiver also with the this connection.
1 - 10 of 10 Posts
Status
