Status
Not open for further replies.
1 - 4 of 4 Posts
I am getting all the Sacto OTA digitals very well with the exception of ABC. It maps at 10.2 with lots of dropouts despite a strong signal. Once, the Sony mapped ABC at 10.1 and it came in perfectly. Has anyone else in Sacto area had this problem? If a station is broadcasting in both 10.1 and 10.2 why doesn't my Sony pick both of them up? I wish they would upgrade the OTA reception so that we could direct enter a channel like 10.1 without having to do a channel search. Anyone know if this is a hardware problem or can a software upgrade fix this?
They are on 10.1 only for NYPD Blue, as far as I can tell. Everything else is SD on 10.2.
My TU-HDS20 takes awhile to lock onto 10.2 but after a minute or so it seems to stabilize. NYPD Blue, last week, was rock stable in HD on 10.1.
Terry
1 - 4 of 4 Posts
Status
