Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
My Sony 30XS955 has an optical audio output. There is also an optical output on the Scientific Atlanta HDTV set-top box that I am using. I bought a Monster Cable to connect the two, but it doesn't seem to be working.
Is the presence of an optical cable between a set-top box and a HDTV supposed to make a difference in the sound the TV produces, or is the optical output on the TV really only there to connect to a speaker system?
Any help on this would be appreciated. Thanks!
· Registered
Discussion Starter · #3 ·
Thanks for the response! That explains why I am getting no sound out of the TV when the cable is run between the STB and the TV. I will have to get a receiver.
1 - 3 of 3 Posts
Status
