Status
Not open for further replies.
1 - 1 of 1 Posts
Has anyone noticed that when the HS-10 is turned on if it goes to the input you are using? The last two days I have left it on memory stick and in about 10 seconds it switched to my component source. I did have the menu setting to auto search set to off. Last night I switched it on and will try again.
1 - 1 of 1 Posts
Status
