I have seen some people ask if the powerstrip settings work with the vga cable but no replies. I finally built my HTPC and gave it a try. works great
Using the 9600xt.
Only complaint I have is I get some type of interference going across my screen untill I start MYHD then it goes away. Doesn't seem to do that when I am not going through the MYHD card. When I try the HD mode on the card it sqishes into a 4:3 window. I have to swithc projector to rgb. Picture looks good but every so often black bars seem to go up and down. This doesn't happen when I use component out with myhd so i will probably swith and have two connections and not do the pass through. Next step is trying the dvi from card and projector. If it works then will buy add on card for the myhd 120.
Using the 9600xt.
