Greetings,
I realize that there are numerous threads regarding the HS10 ( lamp bug etc ). I am going to order the projector this morning and want to try to find out a couple of things.
- Does anyone use the supplied video Multi cable with the HS10, and if so how does it's quality compare to running direct component/S video cables?
- I am going to order a Da lite High contrast Da mat 92" diagonal ( 80 x 45 ) screen. My room is 14 x 23. I am going to ceiling mount the projector 14 feet from the screen. My mounting location is flexible. I have heard that waiting to order the screen is a good idea. I assume that this would be preferable if your mounting location was fixed and it was necessary to ensure proper screen size ( based upon throw/zoom distances etc. ) Anyone else order their screens right away and encounter any issues?
- I am going to have run wire conduit from my component rack to the projector as running it through the walls is not an option. I saw some speaker wire type conduit at Home Depot which might work. Anyone else have any ideas as to the best way to run the cables up the wall to the ceiling?
There is a link below to my webpage which has pics of my setup. The projector will be mounted above the blue couch. The screen will be mounted on the wall where the HDTV is now.
I appreciate any thoughts and or comments.
My home theater
My home theater
