Status
Not open for further replies.
1 - 1 of 1 Posts
Hello to all of you,
first thanks alot for your great forum, esp. all the HS10 information I found here - unbelievable !
I still couldn't find an answer to my DVI setup (HS 10 with a HTPC running at 720p in Video GBR mode using Powerstrip):
In my opinion I only get really sharp letters on the screen using the "Full Through" mode and zooming up afterwards.
But this gives me lots of light around the screen ....
If I use just the "Full Wide" mode, I don't have light around, but the picture quality seems to be degraded.
I'm just a newbie, but the light means my panel isn't used to its full extent ?
Or is there a way to get a sharp picture with the regular "full" mode ?
Thanks for your kind help, majo
1 - 1 of 1 Posts
Status
