Sony HS60(HS51A).. small screen projector?
349 Views 1 Reply 2 Participants Last post by  sbowler579
I'm upgrading my current projector to a 720p projector. I've narrowed it down to the AE900, Z4, and Sony HS60. I'm leaning more towards the Sony but the thing I'm concerned about is if the HS60 be able to handle a 110" screen and still look good? I've read that it's meant for a smaller screen size (less than 100") and others have said it will be able to handle a larger screen size..I just wanted to get your guys' opinion before I make a final decision in what pj I'm going to get.. should I be fine on a 110" screen with the HS60 (I'm currently running the high contrast cinema vision from Da-lite).
Also wondering if I should be seeing a big difference between my current pj and a 720p one? (there's no stores around here where I could demo any of the pj's i'm considering).
Or should I be looking at any other projectors (my budget is around $4,500 or less). I'm limited to about 16-16.5' throw distance. Any feedback is appreciated.
Status
Not open for further replies.
1 - 2 of 2 Posts
I think any of your choices would produce an image the size you require from around 16ft. I would go for the one with the bulb voucher and best deal.
1 - 2 of 2 Posts
Status
