Hi all,
I purchased the Sony HT-CT770 Sound Bar to go with my Sony Bravia 55" TV.
I connected all of my sources directly into the TV and have the supplied optical cable running to the sound bar. I receive sound from the bar but every so often the sound cuts out for a second and comes back in. I have test in Bluetooth mode and it doesn't cut out.
Not sure if anyone else has had this problem but would like to find out if I need to return the unit before the return period is over. Is it possible the cable is bad or is there an issue with the TV?
Thanks for your help.
