Status
Not open for further replies.
1 - 7 of 7 Posts
· Registered
I cannot find the code to program my 15-2116 to control the receiver. I can use the IR Learn on the remote to control the volume, change source, but I cannot find the code to power the unit on and off. Can anyone help? Also, after I have found a code, can I program a macro to turn on the TV, turn on the DBS and turn on the reciever automatically? I have descrete codes for my TV to turn to the S-Video connection and power on the tv, but I need to get the descrete codes to turn on the reciever as well and switch to the video source.
jv
· Registered
Discussion Starter · #3 ·
That was it. Thanks alot! One other thing is that I can't switch inputs. Of course I can't learn from the remote cuz the receiver won't recognize it. Any other suggestions? Anyone know the descretes for this receiver?
jv
· Registered
Discussion Starter · #5 ·
Okay, the remote won't accept 0243, and I am able to switch b/w video and tuner, but the buttons were odd. The 2 button was for Tuner and the 6 Button was for Video, but I moved them w/ the Keymover feature! Very cool! It seems there is no way to switch to DVD so I'll just live with it. I need to manually load the DVD's anyways ;).
· Premium Member
Code 0243 is a Tape deck code, it isn't under RVCR or AMP, its under TAPE.
1. press AUDIO or AUX, whichever you're using.
2. press and hold P
3. press SELECT
4. scroll down to TAPE
5. SELECT, no need to enter the 0243 because thats the only tape in the 2116.
6. exit
1. press AUDIO
2. press and hold P
3. scroll down to KEYMOVER
4. SELECT
5. AUDIO
6. tap P
7. enter 124 or 191, for the dvd command
8. AUDIO
9. pick a key
Substitute other advanced codes for other inputs, once done, reprogram the AUDIO device with setup code RCVR1158.
1 - 7 of 7 Posts
Status
