1 - 4 of 4 Posts
· Registered
looking for some help. Im using the VGA cable and im happy w/ it...except HD movies on the HD-dvd look a bit red. has anyone encountered this problem w/ this particular Sony TV? if so, how did you fix it?
any help would be appreciated.
· Registered
Are you sure it's not the tv causing this? The A10's are notorious for red push. There is a Grand Wega V tweaks thread somewhere in the rear projections forum explaining how to correct it.
· Registered
Discussion Starter · #3 ·
thanks. i'll check in to that.
1 - 4 of 4 Posts
