1 - 2 of 2 Posts
Discussion Starter #1
Well I just check the lamp hrs on my 2 yr old Sony KDF-E55A20 and I'm getting close to the 8,000hr mark and I'm prolly going to have to replace it soon. Does anyone know the correct way to reset the lamp timer so I know when I do decide to replace the lamp?
I'm not sure about your particular model, but the KDF-50E300 has a "Lamp Replacement" option in the General Settings menu.
I quickly looked through the manual for your set and didn't see that issue addressed. Perhaps another owner of the KDF-E55A20 can be of more assistance.
1 - 2 of 2 Posts
