I've had my KDL-26M4000 for a month now and have noticed a couple of things that maybe users here with the same or similar models could help me with.
Whenever I tune into a channel that's 16:9, it doesn't automatically fill the screen like it's supposed to whether auto-wide is on or not.
It has three settings in the Screen part of the menu:
Wide Mode: Wide Zoom, Normal, Full, Zoom
Auto Wide: On, Off
4:3 Default: Wide Zoom, Normal, Full, Zoom, Off
Right now I have Wide Mode set to Full, Auto Wide set to Off and 4:3 Default set to Normal.
Whenever I change to a channel that's supposed to be 16:9 it doesn't automatically fill the entire screen like it's supposed to. I have tried turning Auto Wide to On and it didn't do anything.
Also, I've set my Wii to display at 16:9 and 480p. When I turn the Wii on and change the TV to component input 1 (where the Wii is connected), there are black bars still on both sides of the picture and the TV's "Info. Banner" shows that the input signal is 4:3 when I know I set the Wii to 16:9. I have to manually change the TV's Wide Mode to Full to get the picture to display like it's supposed to and fill the entire screen. However, once I change to a different input like TV / coax. and change back to component input 1, the Wide Mode setting is back to Normal instead of what I just changed it to (Full).
It's like the TV isn't remembering what Wide Mode that input was last set to.
Is the TV not supposed to work that way (remembering each input's Wide Mode setting)?
Or is the Wii not sending the proper signal to the TV so that the TV can detect that the Wii is sending a 16:9 signal?
Auto Wide: On, Off
