1 - 2 of 2 Posts
· Registered
Sony KDL-42V4100 won't see my RGB PC connection
Hello,
I am attempting to connect my pc to my sony tv via the rgb connection, but the tv acts as if there is no signal being received; ie the pc input is greyed out, as though there is no signal at all. I am using a ferrite core male to male rgb cable, decent quality. I used a pc monitor to try different resolutions specified in the tv manual (640x480 60Hz, 800x600 60Hz etc).
I can't get it to work. Any suggestions?
Eric
· Registered
I'd check the Sony manual to see what video resolutions it accepts and set your video card to that resolution before you hook it up to the TV.
Also, check the setup on your Sony to make sure you didn't set up the TV to hide that input. My last Sony allowed me to bypass unused inputs on the set, which helped when switching inputs, but may make is unusable until you reactivate the input setting.
1 - 2 of 2 Posts
