1 - 3 of 3 Posts
I purchased this tv in FEB. 2008.. so its out of waranty. It was working fine up until 3 weeks ago.. it started bleeding.. it takes approx 15 - 25 minutes for it to go away, then it may start bleeding again then go away.. how does this problem get fixed? how costly is it to fix? Will there be any other problems after this one is resolved? Thank you for your help
I diappointed with the tv..I've had other Sony TV's last 20 yrs.
What do you mean by "bleeding"? Is it leaving a puddle of blood on the floor?
Discussion Starter · #3 ·
As it was explained to me... bleeding: the screen does not mix all the colors together and from one frame to another you can still see the previous frame mixed in with the new frame... u put it on wide zoom it does not fill up the whole screen as well as in some spots it stays black for awhile, a tech person stated it was the screen and it cost more to fix than to replace... now what?
1 - 3 of 3 Posts
