1 - 3 of 3 Posts
I know these sets are obsolete but I do have a ? my color is messed up and can not figure out what the heck needs ta be adjusted the issue is green say a scene has a pepsi can or machine, or it has a car that I know for a fact is blue yet its showing it to be green, yet the skies and oceans etc are still blue what is going on here? thanks much for any help on the dinosaur
I HAVE A SONY KDS-R50XBR1 WEGA SXRD REAR PROJECTION TV. AS YOU MIGHT KNOW , THESE SETS ARE KNOW FOR BLOWING BULBS AND OPTICAL BLOCK PROBLEMS. JUST SO HAPPENS THAT SONY REPLACED THE BLOCK IN 2006 DUE TO A RECALL. TV HAS WORKED FINE SINCE. I JUST BLEW ANOTHER BULB, SO IF ANYONE NEEDS THIS SET FOR PARTS, MAKE A REASONABLE OFFER AND I WILL BRING IT TO YOU IF I CAN. IF YOU ARE NEAR BLAIRSVILLE, NORTH GA, COME AND SEE IT. RIGHT NOW THE SET HAS NO BULB, A BROKEN LAMP BULB PLUG CAUSE IT MELTED WHEN BULB BLEW, AND A BARELY NOTICEABLE SMUDGE FROM OPTICAL BLOCK. THESE BLOCKS USE LENSES WHICH ARE SIMPLY REPLACED. I WOULD FIX IT AGAIN, BUT I'VE HAD THIS SET SINCE 2005 BRAND NEW AND ALREADY FIXED IT ONCE. IT'S TIME FOR A SMART TV. PLEASE CALL IF INTERESTED. 7064008345
1 - 3 of 3 Posts
