Am now experiencing about 20 second blanking of the picture every 3 to 5 minutes. The green power light remains on and does not blink. Going into the service menu yields all "0"s on both the LCD engine report and the Main report screen of the self diagnosis menus.
Can you help me identify the probable card that is bad? Are there economical used sources of the internal cards in order to swap the probable bad card(s)?
About 24 months abo the optical block went out and was replaced after a long haggle (5 months plus) with Sony.
Now I just want to replace a card or two within the unit instead unless it turns out to be the optical block again (that remains in extended warranty).
Thanks for any help.
Terry
Terry
