1 - 3 of 3 Posts
We've had our Sony for 8 years...might be time to pull the trigger and replace it.
The problem is the picture has a lot of green in it. I opened her up and all three colors are working. sorry don't know the tech terms. I guessing the are called CRTs. Anyway I found a web page that I can't find again but showed the focus block. I tried to tweak it but I think there might be something more serious wrong.
Any ideas or links to other post?
PDub
Discussion Starter · #3 ·
Originally Posted by primetimeguy /forum/post/18129912
Check your cables, I'm assuming your are using component video connections...one of the 3 connectors may be loose.
You my friend saved me. I had forgot a tech came out a while back and replace our TV receiver and guess what he didn't get it push all the way in. Now I need to adjust the colors. I have too much blue for some reason.
thanks again
1 - 3 of 3 Posts
